เปิดแบนด์ TM-251A ถอดไดโอดตัวไหนครับ ?
กรกฎาคม 16, 2026, 11:29:35 am *
ผู้เขียน หัวข้อ: เปิดแบนด์ TM-251A ถอดไดโอดตัวไหนครับ ?  (อ่าน 18893 ครั้ง)
inquirer
กระทู้: 27
« เมื่อ: มิถุนายน 28, 2008, 12:56:35 pm »
ผมศึกษาวิธีจากนี้  >> http://www.radiomods.co.nz/kenwood/kenwoodtm251.html
This is the wide-banding modification for the Kenwood TM-251E
The mod begins...
Remove both lids,
Remove facia, knobs and vfo nut,
Remove the screw between the volume and squelch pots,
Remove the LCD, carefully, the connectors are fragile,
Remove the cage, it is held on by 4 screws,
Remove the 2 screws holding the control unit in place,
If fitted now remove the memory expansion and CTCSS boards,
The memories will still be there when you are re-building.
Now read this carefully, VERY VERY GENTLY pull of the control unit, this has 2 small connectors holding it in place.
If you are not careful enough, this PCB will flick off into orbit, and possibly be damaged.
Here we are, getting the soldering iron ready...
Locate D417 on the PCB. It is the one at the edge of the board, very close the IC401 which is a MD6433388F (Opposite side to knobs.)
To confirm this diode is the correct one, check using a digital meter that one end is connected to pin 60 of the above chip. The other end should be connected to pin 65 of the same chip VIA a 100ohm resistor.
Remove this diode. Check to see if the wire links are attached. If they are (I don't expect them to be) then remove them. These are marked W1, W2, W3 on the PCB.
Go have a cup of coffee now, then come back and put the radio back together again.
Do a CPU reset by powering up with MR pressed (Bye memories!)
Note: Sometimes a CPU reset isn't required, so do not do this initially, only do a reset if the radio malfunctions in some way when powered up.
Oh look, the radio will now receive and transmit from 136MHz to 174MHz, and also receive from 300Mhz to 470MHz.
If you also look at the menu's avaiable you will see a new one.
End of mod. Did you succeed or kill the radio? Let me know ok?
แต่หาไดโอดตัวที่เค้าบอกมายากมากๆ  งบอยู่นานก็ไม่เจอเลย      ขอคำแนะนำด้วยครับ
inquirer
กระทู้: 27
« ตอบ #1 เมื่อ: มิถุนายน 28, 2008, 02:01:59 pm »
แฮะๆ  นับอย่างไรครับ  ขา 1  ถ้าจากรูปนะครับ
« ตอบ #2 เมื่อ: มิถุนายน 28, 2008, 02:16:04 pm »
ดูจากรูป น่าจะเป็นฝั่งที่มีรอยบาก
inquirer
กระทู้: 27
« ตอบ #3 เมื่อ: มิถุนายน 28, 2008, 10:02:58 pm »
ขา 1  นับเริ่มจาก ที่ลูกศรชี้  และ ขา 2 .. 3   .. นับต่อไปยังทิศทางลูกศรชิ้ใช่ไหมครับ ?
« ตอบ #4 เมื่อ: มิถุนายน 28, 2008, 10:26:35 pm »
ถูกต้องครับ
inquirer
กระทู้: 27
« ตอบ #5 เมื่อ: มิถุนายน 28, 2008, 10:59:01 pm »
ขอบคุณครับ   Cheesy
inquirer
กระทู้: 27
« ตอบ #6 เมื่อ: มิถุนายน 29, 2008, 11:03:44 am »
เท่าที่ผมเตรวจสอบดู   ปรากฏว่า  ไดโอดตัวนี้มันถอดแล้ว  แต่ทำไมยังไม่เปิดแบนด์ก็ไม่รู้
ของผมเป็น TM-251A  แต่ข้อมูลการเปิดแบนด์ข้างบนเป็น TM-251E ไม่รู้จะเหมือนกันไหม?
มีข้อแนะนำอื่นๆไหมครับ
hs3ldy
คะแนน11
กระทู้: 237
มนุษย์ต่างดาว
« ตอบ #7 เมื่อ: มิถุนายน 29, 2008, 11:37:20 am »
ขอบคุณทุกท่านใด้ความรู้อีกแล้ว
« ตอบ #8 เมื่อ: มิถุนายน 29, 2008, 12:13:05 pm »
เขาหมายถึง ให้ใส่ไดโอด  1N4148  ที่ตำแหน่ง D417   กับใส่ R 100 โอห์ม  ที่ขา 60 กับ 65   หรือป่าวครับ   ภาษาอังกฤษ ผมไม่แข็งแรงซะด้วยซิ
inquirer
กระทู้: 27
« ตอบ #9 เมื่อ: มิถุนายน 29, 2008, 12:40:32 pm »
ผมเข้าใจ่ว่าเมื่อรู้ตำแหน่งไดโอดแล้ว   ถอดมันออก  และดูว่าถ้ามีสายลิงค์อยู่   ก็ให้ถอดมันออก  มันคือที่เขียนไว้เป็น W1,W2 และ W3 บนแผ่นปริ้นท์   สุดท้ายให้ทำรีเซทโดยกดปุ่ม MR  และเปิดสวิทช์พร้อมกัน  ( ช่องเมมจะหายไปด้วย)
ผมก็ทำตามนี้   และตัดสายลิงค์ทั้งสาม ผลคือ  เครื่องเปิดแล้วไม่ทำงาน   ต้องต่อสายทั้งสามกลับตามเดิม     ไม่รู้ทำผิดเพราะไม่ไปกินกาแฟแบบที่มันบอกมาไหม ?   ฮ่า   ฮ่า
แต่ไม่ได้หาไดโอด 416 ชึ่งบอกไว้ว่าสำหรับเปิดแบน์ดรับอย่างเดียว (ไม่รู้เหมือนกันว่า   ที่มันเปิดแบนด์รับได้อย่างเดียวตอนนี้  เพราะถูกถอดออกหรือเปล่า ?   และต้องใส่กลับเข้าไปไหม ? )
boony
คะแนน27
กระทู้: 286
boonybaw@hotmail.com
« ตอบ #10 เมื่อ: กรกฎาคม 01, 2008, 09:59:22 am »
W2 สายไฟสี่ ฟ้า ที่ ในรูป มัน ถูก ตัด หรือ เปล่าครับ ถ้าไม่ได้ ถูกตัด ลอง ตัดมันให้ขาด แล้ว ลอง ดู ปกติ  kenwood จะไม่ต้องทำอะไร มาก ตัดสายไฟ เส้น เดียว ก็ เปิกแบน์แล้ว
w w w .6173it.com
แบ่งแบ่งกันไป
inquirer
กระทู้: 27
« ตอบ #11 เมื่อ: กรกฎาคม 01, 2008, 05:15:17 pm »
มีสายไฟ 3 เส้นครับท่าน  แต่ผมยังไม่เคยตัดเฉพาะเส้นหนึ่งเส้นใด   ได้แต่ลองตัดทั้ง 3 เส้น  แต่ทำแล้ว  วิทยุเปิดแล้วไม่ทำงาน  จึงใส่กลับเข้าที่เดิม
ฝรั่งมันแนะนำมาให้ถอดไดโอดออกด้วย   และผมได้ตรวจแล้วพบว่ามันก็ถูกเอาออกมาแต่แรกแล้ว
จึงได้แต่งงๆๆ
X--LSV team
คะแนน105
กระทู้: 58
« ตอบ #12 เมื่อ: กรกฎาคม 01, 2008, 06:41:23 pm »
เอา D416 ใส่ดู แล้วลองอีกที  ผมเดาเอานะ
น่าเห็นใจนะครับ ถามทั้ง Weekend / 100watts  /etc ยังไม่ได้คำตอบ
inquirer
กระทู้: 27
« ตอบ #13 เมื่อ: กรกฎาคม 01, 2008, 09:22:09 pm »
ขอบคุณครับ  แหม ก็รอๆอยู่นะ  ว่าเมื่อไหร่น้า  จะมีใครมาช่วยเราคิดบ้าง   ฮ่า ฮ่า    จะพยามยามลองอีกครั้งครับตามที่แนะนำ (วันนี้อุตส่าห์ไปหาช่างทำให้แล้วด้วยซ้ำไป   ช่างเค้าไม่มีข้อมูล  คงเป็นเพราะรุ่นนี้ใช้กันน้อย)
inquirer
กระทู้: 27
« ตอบ #14 เมื่อ: กันยายน 15, 2008, 07:30:50 pm »
ทำสำเร็จแล้ว  พอดีวันนี้มาทำต่อ  หลังจากวางไว้นาน
สรุปคือเอาไดโอด D416 และ D417 ตามรูปออกทั้งคู่   สาย W1 , W2 , W3   ไม่ต้องตัด
