Error code ของ Canon
มิถุนายน 26, 2026, 07:13:50 pm *
ผู้เขียน หัวข้อ: Error code ของ Canon  (อ่าน 7245 ครั้ง)
ope3
คะแนน39
กระทู้: 139
ท้อได้แต่ห้ามถอย
ope172010@hotmail.com
« เมื่อ: มิถุนายน 22, 2008, 04:47:00 pm »
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Clear Buffer
Clear Buffer Printer Canon PIXMA IP Series IP3000 IP3300 IP3500
ถ้าขึ้นไฟกระพริบ 16 ครั้ง(หมึกสีหมด) กระพริบ 4 ครั้ง (หมึกดำหมด) ให้กด Resume ค้าง 5 วินาที
Canon inkjet Printer PIXMA iP1500
Waste Ink Counter Reset.
Canon inkjet printer PIXMA iP1000
Printer Canon GENERIC "S" SERIES RESET CODE
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in
succession. Note: you are still holding the POWER button). The printer's carriage will "reset"
or move momentarily. If the above was properly performed the printer will enter the
"Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp
will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM - Initialization.
4. Reset the Waste ink counter.
5. Printer model setting. (More selections beyond this point - However it is best leave them
unaltered - You have been warned!)
After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Manual for Service mode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
should be orange.
Clear Buffer Canon Inkjet Printer "S" Series Canon BJC-210 BJC-240 BJC
Canon BJC 1000 inkjet Printer Serie
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Canon BJC-2000 BJC-2100 inkjet Printer Serie
1: Remove the Cartridge
3: Close Front access panel
4: Hold down the RESUME/RESET button and plug in the AC power cord
5: Release RESUME/RESET after plugging in the AC Power cord.
6: Press the RESUME/RESET once within 5 seconds and release the RESUME/RESET .
7: Press and HOLD RESUME/RESET for two seconds or more and release it.
8: Press and HOLD RESUME/RESET for two seconds or more and release it.
9: Unplug AC Power Cord to set data.
Canon Inkjet Printer Series
Canon BJC-210 BJC-240 BJC-250 BJC-255 BJC-265
Canon BJC-4100 BJC-4200 BJC-4300 BJC-4400 BJC-4550 BJC-4650
1.Unplug Power Cord
2.Hold POWER and RESUME buttons
3.Plug in Power Cord
4.Release buttons
5 front door of printer
6.Hold the CARTRIDGE and RESUME buttons
7.Press POWER
Release all buttons after the beeps
Press CARTRIDGE once
Press RESUME
Canon inkjet Printer BJC-5000
1: Power off printer
2: Press and hold RESUME then press POWER, The indicator will start blinking.
3: While the indicator is blinking ,
4:Press RESUME twice then Wait until the printer beeps to indicate service mode
5: When the indicator lights steady GREEN,
press RESUME four(4)times. The indicator should be GREEN.
6: Press Power to set data
Service Test Print
5: When the indicator lights steady GREEN, press RESUME two(2)times.
6: Press Power to Print
Nozzle Print
2: Press and POWER, until the printer beeps and release.
Demonstration Print
1: While the printer in ON , , Press and hold RESUME until the printer plays a melody of beeps.
Canon inkjet Printer BJC-5100
Self Test
Switch Printer off. Hold Power for 1 beep.
Waste Counter Reset
4: When the indicator lights steady GREEN, press RESUME four(4)times. The indicator should be
GREEN.
5: Press Power to set data
Service Test Print
Nozzle Print
Demonstration Print
Canon Inkjet Printer series.
Canon BJC-3000 BJC-6000 BJC-6100 BJC-6200 S400 S450 F300 F600 F620
Canon BJC-7000 BJC-7100 BJC-8000 BJ-F800 i6500
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
Inkjet Printer
Canon BJC-600 BJC-600e BJC-610 BJC-620
1: Unplug Power Cord
2: Hold POWER and FF and Print Mode buttons
3: Plug in Power Cord
4: Release after the beeps
Inkjet Printer
Canon BJC-50 BJC-55 BJC-80 BJC-85 M40 M70
2: Hold POWER and RESUME buttons
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
Inkjet Printer
Canon BJ-30 BJC-35v BJC-70
F14 Error Reset
1: Unplug adapter
2: Hold POWER
3: Plug in ADAPTER
4: Release POWER after printer starts
5: Hold FF and MENU and press POWER
6: Release after beeps
7: Press <> Cartridge until 1A is displayed
8: Press ONLINE
9: Press POWER to shutoff printer
10: Unplug printer then re-plug printer
Inkjet Printer
Canon BJ F900, F890, F700, F500, S900, S820, S750 and S520
Release the RESUME button, then press and release the RESUME button two more times in succession. (youre still holding the POWER button during this). The printer mechanics will move momentarily.
You are now in Service mode.
Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
1. service/factory test printout, including ink sensor check
2. EEPROM info printout
3. EEPROM initialization
4. Clear the waste-ink counter
5. Printer model setting. (more selections beyond this- leave this alone)
After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart
Reset ink Counter Canon Mp150/160 Printers
Befor Clear buffer Printers Canon inkjets printers
Enter Service Mode
Enter service Mode See code for reset belows
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Create Date : 25 เมษายน 2551
Last Update : 21 มิถุนายน 2551 9:33:40 น.   0 comments
hormok♥
สนับสนุนLSV-server
คะแนน245
กระทู้: 659
« ตอบ #1 เมื่อ: มิถุนายน 22, 2008, 10:28:00 pm »
ขอบคุณมากครับ
