Studio 350 Power Amplifier Module
ตุลาคม 04, 2025, 11:49:17 pm *
ผู้เขียน หัวข้อ: Studio 350 Power Amplifier Module  (อ่าน 20006 ครั้ง)
sawasdee_patipan
กระทู้: 31
« เมื่อ: มิถุนายน 03, 2007, 12:38:39 am »
ลองดูครับ ตามสั่งครับ พี่นิมิตร Grin Tongue Embarrassed
sawasdee_patipan
กระทู้: 31
« ตอบ #1 เมื่อ: มิถุนายน 03, 2007, 12:45:34 am »
รายละเอียดครับ Tongue Embarrassed
To help ensure that everything goes together without a hitch, it's a good idea to read the following information in its entirety before reaching for your soldering iron!
Referring to the overlay diagram in Fig.1, begin by installing all the wire links. There are 15 links in total, 11 of which must be formed from 1mm tinned copper wire. Use 0.7mm wire for the remaining four links. The overlay diagram shows the larger (1mm) links in red.
Set aside all of the heatsink-mounted transistors (Q4-Q17), the two 470μF electrolytic capacitors, choke (L1) and 6.3mm spade lugs for the moment. We'll deal with these in more detail shortly. All other components can now be installed, progressing from smallest to largest.
The 1W and 5W resistors should be mounted about 1mm proud of the PC board to aid heat dissipation. Also, be sure to orient the cathode (banded) ends of diodes D1-D5 as shown.
When installing the fuse clips, note that the small retaining lug on each clip must be positioned to the outer (fuse end) side, otherwise fuse installation will be impossible.
If you intend mounting the output transistors horizontally, then it's also necessary to install 3-pin header strips in the mounting positions for Q8 & Q9. As we'll see shortly, these are required because the transistor leads are too short to extend all the way through the PC board holes.
Fig.1: use this diagram when assembling and wiring the amplifier module. The ±70V wiring is routed underneath the board and attached to it with cable ties once testing is complete.DANGER: HIGH VOLTAGE!
The 140V DC supply across the filter capacitor bank and the amplifier supply rails is potentially lethal! After the power supply wiring is complete and before you apply power, mount a clear Perspex sheet over the capacitor bank to protect against inadvertent contact - now or in the future! Note that the capacitors take some time to discharge after the power is switched off.
« ตอบ #2 เมื่อ: มิถุนายน 16, 2007, 08:45:57 am »
ขอบคุณครับ  ที่นำมาลง  พอดีผมออกนอกระบบไประยะนึงเลยไม่ได้มาอ่าน
kt_direx
กระทู้: 5
« ตอบ #3 เมื่อ: กันยายน 21, 2008, 04:44:39 pm »
สนใจจะซื้อชุดนี้ครับ มีจำหน่ายที่ไหน สเปก และราคาด้วยครับ ยังไงก็ขอรายละเอียดด้วยนะครับ kt_direx@hotmail.com
ไทคอนสาร
กระทู้: 228
pssxsx@hotmail.com
« ตอบ #4 เมื่อ: กันยายน 25, 2008, 01:06:39 pm »
ใช่อันนี้ไหมครับ...รอสักครู่ ภาพจะปรากฏขึ้นมา Tongue
 wav!!
 wav!!
 wav!!
 wav!!
gAudio
กระทู้: 78
« ตอบ #5 เมื่อ: ตุลาคม 01, 2008, 06:01:52 pm »
ท่านใดลองทำแล้วบ้างครับ
ผลเป็นอย่างไร
ฝรั่งเขาวางยาอะไรไว้หรือเปล่าครับ
อยากลองทำดูครับ
KS.SOUND
กระทู้: 48
« ตอบ #6 เมื่อ: ตุลาคม 29, 2008, 02:38:45 pm »
อยากรู้จังว่าเสียงเป็นอย่างไร ช่วยหน่อยนะ wav!!
BOY-DYNASAT
คะแนน8
กระทู้: 100
« ตอบ #7 เมื่อ: มีนาคม 26, 2010, 04:39:40 pm »
อยากรู้มีใครลองหรือยังครับ
มีวางยาหรือเปล่าสนใจเหมือนกันครับ  ping!
dB_WB
กระทู้: 147
« ตอบ #8 เมื่อ: มิถุนายน 10, 2010, 10:50:03 am »
ถึงหรือครับ 350@8 ohm  กลัวได้ที่ 4 โอห์ม
อุปกรณ์น้อยดีจัง คุณภาพเป็นอย่างไรครับ ใครทดสอบมาบ้าง
ชอบตรงที่ Input direct coupling สัญญาณความถี่ต่ำๆ ก็คงสดดี
   help!!!
prapakorn
กระทู้: 31
อิเล็กทรอนิกส์ไทยจงเจริญ
« ตอบ #9 เมื่อ: มิถุนายน 21, 2010, 09:43:41 pm »
ทำแล้วครับ แต่ทำเป็นแอคทีฟซับวูฟเฟอร์แปลงวงจรนิดหน่อยเพื่อให้ตอบสนองความถี่ต่ำให้ดีขึ้น แล้วใส่ซับวูฟเฟอร์ฟิลเตอร์ เสียงดีนุ่มครับ มีสูตรตู้ซับ 10 นิ้วมาให้ด้วย แต่ขอบอกว่าขับซัพ 12 นิ้วออกดีกว่า10 นิ้วมาก กระฮึ่มๆ ตอนนี้ทำแจกญาติๆ และขายเพื่อนๆ ไปหลายตัวแล้วครับ
ปล.แก้ยานิดหน่อยนะครับ
ตอนนี้แค่นี้ไปก่อน แต่ตอนหน้าข้าต้องเจ๋ง..
dB_WB
กระทู้: 147
« ตอบ #10 เมื่อ: มิถุนายน 21, 2010, 10:02:30 pm »
พอจะบอกได้เป่าคับว่า แก้จุดใหนบ้าง
จะทำมั่ง  lv!
   help!!!
dB_WB
กระทู้: 147
« ตอบ #11 เมื่อ: มิถุนายน 22, 2010, 11:24:16 am »
วงจรนี้ 200W@8ohm  และ 350W@4ohm
ผมคิดว่า แก้เรื่องเบสน่าจะแก้ที่ Feedback และจุดเน็ทเวอร์ค input  สำหรับผมถ้าจะทำคงแก้เรื่องวงจรปรับกระแสไดเดิ้ล และฟีดแบ๊คนี่ล่ะครับ
อยากรู้จังว่า S/N, THD และ Damping ได้เท่าใหร่น๊อ พอจะทดสอบให้ดูได้ใหมครับ
dB_WB
กระทู้: 147
« ตอบ #12 เมื่อ: มิถุนายน 22, 2010, 11:27:49 am »
Delivers 200W RMS in 8 Ohms or 350W RMS into 4 Ohms. Very low distortion.
Perfect amp module for DJ's or home studios wanting plenty of grunt, without compromised sound quality.
Specifications
Output Power 200W into 8 Ohm; 350W into 4 Ohm
Music Power 240W into 8 Ohm; 480W into 4 Ohm
Frequency Response -1dB at 15Hz and 60kHz at 1W
Input Sensitivity 1.75V for 200W into 8 Ohm
Harmonic Distortion Typically .002% at normal listening levels
Signal-to-Noise Ratio -122dB unweighted (22Hz to 22kHz); -125dB
A-weighted, both with respect to 200W into 8 Ohm
Damping Factor <180 at 100Hz; <75 at 10kHz, with respect to 8 Ohm
Protection 5A supply fuses
Stability Unconditional
dB_WB
กระทู้: 147
« ตอบ #13 เมื่อ: มิถุนายน 25, 2010, 01:55:14 am »
อีกอย่างถ้า Damping สูงๆ หน่อยจะสุดยอดมากครับพี่น้อง
